[GRASS-user] r.fillnulls in the latest cvs version doesn't work appropriately
Mon Feb 12 07:36:04 EST 2007
Martin Landa wrote:
> I am trying to revert the changes. I think it is better to implement
> print option from the scratch then trying to change the existing flags
> behaviour. I agree that all scripts written for GRASS 6.x should work
> without any modification. These changes should come with new version
> of GRASS (GRASS 7.x). The question is when it will be. Maybe we should
> collect more detailed ideas for GRASS7.
There's no reason why you can't add the print= option in 6.x. Adding
entirely new functionality is safe, so long as it doesn't affect
anything which doesn't explicitly use it.
