[GRASS-user] Grass62 on X86_64
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Feb 13 03:14:33 EST 2007
Craig Aumann napisał(a):
> I'm installing grass 62 on a Fedora 6, X86_64 machine.  Originally, I
> just pulled off the i386 rpms and installed those, but discovered that
> they were NOT compiled with postgresql support for some reason.  While I
> don't mind compiling grass62 again with this support, the problem is
> that the installed support libraries (gdal, proj, etc) are only for
> i386...  This is leading to all sorts of problems. How to find these
> libraries for x86_64, etc...
> Given that there are many other things I would rather be doing and need
> to do than screw around with this, what's the fastest, easiest solution
> here?
> thanks
> Craig
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
generally, gdal and proj are very easy to compile on 64 bit
architecture. Simply compile these libraries insted of installing them
from packages
J.
