[GRASS-user] Re: Cygwin winGRASS 6.2 Errors!
yuri bay
ksh_wong at msn.com
Tue Feb 13 12:24:21 EST 2007
To Hamish and everyone,
>From: Hamish <hamish_nospam at yahoo.com>
>To: "yuri bay" <ksh_wong at msn.com>
>CC: grassuser at grass.itc.it, wingrass at grass.itc.it
>Subject: Re: [GRASS-user] Re: Cygwin winGRASS 6.2 errors
>Date: Tue, 13 Feb 2007 12:34:17 +1300
>yuri bay wrote:
> > I have encountered the following error when I first time invoked the
> > Cygwin winGRASS 6.2 after I have successfully installed it. I am
> > using both native binary and the new cygwin 6.2 winGRASS. I have
> > copy and past my GRASSDATA dir into cygwin directory so that I can
> > access the same data using cygwin winGRASS. But when I have selected
> > the correct directory and mapset, the following error occured on the
> > xwindow:
> > GRASS 6.2.1 (L_UK):~ > child process exited abnormally, by using gis.m
> > on the xwin will give the same error.
>what does it say if you type "g.region -p" at that prompt?
>"d.mon x0" ?
>"gis.m" ?
With gis.m or "gis.m" the results are the same, child process exited
abnormally
With d.mon x0, a monitor is activated.
With g.region -p, there is no respond or error
and for all the child process errors shown on the Xwindow, the errors shown
in the Cygwin command prompt is:
winMultiWindowxMsgProcErrorHandler - Error: Badwindow (invalid Window
parameter)
What seem to be the problem?? why can I open a mapset within a location in
the grass_data directory when they are properly configured?
Any help is much appreciated.
Regards
Casey Wong
_________________________________________________________________
Click Here To Find Your Perfect Match This Valentines!
http://msnuk.match.com/
