[GRASS-user] Grass62 on X86_64
Glynn Clements
glynn at gclements.plus.com
Wed Feb 14 18:42:34 EST 2007
Brad Douglas wrote:
> > We had enough problems building GRASS on FC6 that Markus had to help us by
> > directly logging into the machine. It turned out to be a very minor issue,
> > but infuriatingly difficult to find. Probably a growing number of people are
> > in the process of upgrading to FC6 so I'd like to add my vote for a binary
> > when you have time.
> Okay. I'll try to throw something together for the 6.3 preview. There
> won't be PostgreSQL support unless I can find a way to make it
> completely modular.
AFAICT, that shouldn't be an issue any more.
When I made the Cygwin binaries, I followed the historical procedure
of: build --without-postgres, then enable it and build the PostgreSQL
driver. The reason for this was so that NVIZ doesn't require libpq to
run.
However, it appears that NVIZ has long since stopped using libpq
(runPg.c is there, but it doesn't get compiled or linked). AFAICT, if
you build --with-postgres, the only program which will end up with a
dependency upon libpq is the PG driver (driver/db/pg).
OTOH, I could have sworn that someone was having problems quite
recently due to something (other than the PG driver) needing libpq.
