[GRASS-user] kriging with GRASS 6.2 and R
Roger Bivand Roger.Bivand at nhh.no
Mon Feb 19 07:44:23 EST 2007
On Mon, 19 Feb 2007, Dr. Manuel Seeger wrote:
> Hallo all,
> I'm trying to generate a DEM with kriging and trying the workout given
> in the wiki.
> When generating the R SpatialGridDataFrame I get this error:
> Fehler in validObject(.Object) : invalid class "SpatialGridDataFrame"
> object: invalid object for slot "data" in class "SpatialGridDataFrame":
> got class "list", should be or extend class "data.frame"
> I know, its not really a GRASS issue, but perhaps someone can help, what
> I'm doing wrong!
The problem you have found is caused by a mismatch of R packages. Please
update both "sp" ans "spgrass6" from CRAN - use for example
update.packages(). I think that spgrass6 is not up to data - if it was, it
would know that for R >= 2.4 and sp >= 0.9, it needs to provide a
data.frame object, not a list object.
Please follow up on the STATGRASS list - there are plenty of willing and
well-informed helpers there!
http://grass.itc.it/statsgrass/index.php
Roger
> Thanks
> Manuel
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
