[GRASS-user] importing vmap1 data
    Yves Jacolin
    yjacolin at free.fr
    Mon Feb 19 08:34:28 EST 2007
Le Lundi 19 Février 2007 14:10, Jaime Carrera a écrit :
> Hi list,
> Does somebody know how to import vmap1 data in GRASS?
> Thanks,
> Jaime
First of all, you need to install gdal with the OGDI format support (not build
by default), so you probably need to build your own gdal-ogr command.
Then you can run :
ogr2ogr contourl.shp gltp:/vrf/mnt/data/v0eur/vmaplv0/eurnasia
“contourl at elev(*)_line”
to convert vmap to shapefile. Avoid to mix upper and lower case in your path !
Then you can import them into GRASS.
Regards,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
