[GRASS-user] importing vmap1 data
Moritz Lennert mlennert at club.worldonline.be
Mon Feb 19 09:02:54 EST 2007
On 19/02/07 14:34, Yves Jacolin wrote:
> Le Lundi 19 Février 2007 14:10, Jaime Carrera a écrit :
>> Hi list,
>> Does somebody know how to import vmap1 data in GRASS?
>> Thanks,
>> Jaime
> Hi,
> First of all, you need to install gdal with the OGDI format support (not build
> by default), so you probably need to build your own gdal-ogr command.
> Then you can run :
> ogr2ogr contourl.shp gltp:/vrf/mnt/data/v0eur/vmaplv0/eurnasia
> “contourl at elev(*)_line”
> to convert vmap to shapefile. Avoid to mix upper and lower case in your path !
> Then you can import them into GRASS.
Also see Markus' article on VMAP0 in the GRASS newsletter Nr. 3:
http://grass.itc.it/newsletter/grassnews3.html
Moritz
