[GRASS-user] Fwd: concentric circles/regions in vector
Joel Pitt
joel.pitt at gmail.com
Tue Feb 20 19:51:12 EST 2007
---------- Forwarded message ----------
Date: Feb 21, 2007 12:58 PM
Subject: concentric circles/regions in vector
To: GRASSLIST <grasslist at baylor.edu>
Hi all,
I'm trying to create a vector of concentric circles showing a spread
phenomenon and attaching a year to each circle. Currently I am looping
through the following process:
# Create circle
"v.buffer input=%s output=%s buffer=%f" % (centre_map_name,uniform_name,radius)
# add table with year column to uniform_name map
'v.db.addtable map=%s columns="year int" ' % (uniform_name)
# update uniform_name map DB with year
'v.db.update map=%s column=year value=%d' % (uniform_name,year)
# merge with existing map
"v.patch --o -e -a input=%s output=%s" % (uniform_name, merge_map)
This creates a vector map with concentric circles, but I am unable to
select them using "year=2000" - only a point/centroid shows up.
So my question is whether vector types other than centroids/points can
link to a row in a database table?
If not, then can anyone think of a way to do something similar? I'd
rather not have to have excessive numbers of vector maps.
Thanks for any help,
-Joel
"Unless you try to do something beyond what you have mastered, you
will never grow." -C.R. Lawton
-Joel
