[GRASS-user] Re: grassuser Digest, Vol 10, Issue 46
    Daniel McInerney
    daniel.mcinerney at ucd.ie
    Fri Feb 23 08:37:18 EST 2007
Hi Bryan,
> The next item I wanted to ask about is where I might be able to obtain
> GRASS data for Ireland.  I'm looking for the following: Coastline of
> Ireland, contours, archaeological sites, waterways, county lines,
> roadways and cities.  The last three are the least important.  I would
> like to do personal research using a GIS of Ireland.
You'll find archaeological sites data as e00 coverages at [1] and you
can use v.in.e00 to import them into GRASS. There are other spatial
datasets for Ireland available at [2]. I would also recommend using
the GSHHS data for coastlines as was suggested by Maciej earlier.
Regards,
Daniel.
[1] http://www.heritagedata.ie
[2] http://mida.ucc.ie
