[GRASS-user] Installing on Windows XP 64
gary lists at lazygranch.com
Sun Feb 25 19:04:28 EST 2007
X64 has a bug in it related to opening large files with 32 bit software.
  Worse yet, it is not very repeatable, but the bug crops up with
programs like photoshop and open office calc. [Even CS3 isn't compiled
for x64!) The problem is in gdi32.dll. I don't know if this will be a
problem for GRASS, but I think it's likely to be.
That said, I really suggest installing suse 10.2 and just running grass
in linux. It isn't very hard to compile. This way you will get real 64
bit performance. Probably not in memory space, but there are additional
instructions used when running 64 bit code. Suse 10.2 will dual boot.
Hamish wrote:
>> Hi Everyone,
> Hi Andrew,
>> I've done a quick search of the mailing list but haven't come across
>> anything:  Has anyone been able to get a working installation on XP64?
>> It just so happens that this is the computer I need to get GRASS onto,
>> so I'd appreciate your thoughts on it.  Specifically, I need to use
>> the 3D Raster functions of the newer release.
> GRASS 6.2.1 for MS Windows:  (with Cygwin)
>   http://grass.itc.it/grass62/binary/mswindows/
> no idea if there are Win+64bit issues, but try it and see..
> good luck,
> Hamish
> ps-
>> The information contained in this email message is privileged
>> and confidential information intended only for the use of the
>> party named above.  If the reader of this message is not the
>> intended recipient, you are hereby notified that any
>> dissemination, distribution or copying of this communication
>> is strictly prohibited.  If you have received this communication
>> in error, please immediately notify us and delete the message
>> from your system.  Thank-you.
> It is not appropriate to send legal disclaimers of this sort to a
> public list.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
