[GRASS-user] Installing on Windows XP 64
Jonathan Greenberg
greenberg at ucdavis.edu
Mon Feb 26 16:11:06 EST 2007
I've been hearing about this large file bug in Windows, but I *routinely*
open files >> 10gb within RSI's ENVI, so I feel there is something else
going on here. Certainly there's a memory management issue due to the 32
bit memory calls, but that isn't the same as being able to read/write large
files. Most raster calculations need minimal memory anyway, since they are
most efficiently (memory-wise) done using tiled processing. GDAL's support
for large files under Windows has been sporadic, and my understanding was
that it had a lot to do with the cygwin environment and continuing LFS
issues with that.
I had a lot of success getting Debian linux running within a windows
environment using Virtual PC (which is now free !!!) and had flawless LFS
for GDAL (I was using it to run starspan).
--j
On 2/25/07 4:04 PM, "gary" <lists at lazygranch.com> wrote:
> X64 has a bug in it related to opening large files with 32 bit software.
> Worse yet, it is not very repeatable, but the bug crops up with
> programs like photoshop and open office calc. [Even CS3 isn't compiled
> for x64!) The problem is in gdi32.dll. I don't know if this will be a
> problem for GRASS, but I think it's likely to be.
> That said, I really suggest installing suse 10.2 and just running grass
> in linux. It isn't very hard to compile. This way you will get real 64
> bit performance. Probably not in memory space, but there are additional
> instructions used when running 64 bit code. Suse 10.2 will dual boot.
> Hamish wrote:
>>> Hi Everyone,
>> Hi Andrew,
>>> I've done a quick search of the mailing list but haven't come across
>>> anything: Has anyone been able to get a working installation on XP64?
>>> It just so happens that this is the computer I need to get GRASS onto,
>>> so I'd appreciate your thoughts on it. Specifically, I need to use
>>> the 3D Raster functions of the newer release.
>> GRASS 6.2.1 for MS Windows: (with Cygwin)
>> http://grass.itc.it/grass62/binary/mswindows/
>> no idea if there are Win+64bit issues, but try it and see..
>> good luck,
>> Hamish
>> ps-
>>> The information contained in this email message is privileged
>>> and confidential information intended only for the use of the
>>> party named above. If the reader of this message is not the
>>> intended recipient, you are hereby notified that any
>>> dissemination, distribution or copying of this communication
>>> is strictly prohibited. If you have received this communication
>>> in error, please immediately notify us and delete the message
>>> from your system. Thank-you.
>> It is not appropriate to send legal disclaimers of this sort to a
>> public list.
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
