[GRASS-user] help with ogr2ogr and .shp file
    antonio rodriguez
    antonio.raju at gmail.com
    Wed Feb 28 14:39:02 EST 2007
I need some help and advice to transform a .shp file to a format
readable by GRASS. My shape file is as follows:
#ogrinfo -so hs1-1500.shp hs1-1500
INFO: Open of `hs1-1500.shp'
using driver `ESRI Shapefile' successful.
Layer name: hs1-1500
Geometry: Line String
Feature Count: 4962
Extent: (100528.742188, 3991489.250000) - (610083.250000, 4288506.900918)
Layer SRS WKT:
(unknown)
FNODE_: Real (11.0)
TNODE_: Real (11.0)
LENGTH: Real (18.5)
HS1_100_: Real (11.0)
HS1_100_ID: Real (11.0)
COD_ENT: String (4.0)
NOMBRE: String (80.0)
JERARQUIA: Real (11.0)
TIPO_LIN: Real (11.0)
I need to convert it to thi lat/lon region:
GRASS 6.0.2 (andalucia):~ > projection: 3 (Latitude-Longitude)
zone:       0
datum:      wgs84
ellipsoid:  wgs84
north:      39N
south:      36N
west:       8W
east:       1W
nsres:      0:00:03.6
ewres:      0:00:03.6
rows:       3000
cols:       7000
Thanks in advance,
Antonio
