[GRASS-user] help with ogr2ogr and .shp file
Wolf Bergenheim
wolf+grass at bergenheim.net
Wed Feb 28 17:05:43 EST 2007
You have to create a new location for it (the location parameter) and
then project it to your current location with the v.proj module.
--Wolf
antonio rodriguez wrote:
> Hi,
> I need some help and advice to transform a .shp file to a format
> readable by GRASS. My shape file is as follows:
> #ogrinfo -so hs1-1500.shp hs1-1500
> INFO: Open of `hs1-1500.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: hs1-1500
> Geometry: Line String
> Feature Count: 4962
> Extent: (100528.742188, 3991489.250000) - (610083.250000, 4288506.900918)
> Layer SRS WKT:
> (unknown)
> FNODE_: Real (11.0)
> TNODE_: Real (11.0)
> LENGTH: Real (18.5)
> HS1_100_: Real (11.0)
> HS1_100_ID: Real (11.0)
> COD_ENT: String (4.0)
> NOMBRE: String (80.0)
> JERARQUIA: Real (11.0)
> TIPO_LIN: Real (11.0)
> I need to convert it to thi lat/lon region:
> GRASS 6.0.2 (andalucia):~ > projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 39N
> south: 36N
> west: 8W
> east: 1W
> nsres: 0:00:03.6
> ewres: 0:00:03.6
> rows: 3000
> cols: 7000
> Thanks in advance,
> Antonio
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
<:3 )---- Wolf Bergenheim ----( 8:>
