[GRASS-user] help with ogr2ogr and .shp file
Wed Feb 28 23:56:32 EST 2007
antonio rodriguez wrote:
> I need some help and advice to transform a .shp file to a format
> readable by GRASS.
from within your lat lon GRASS location:
v.in.ogr location=
to import the shape file and create a new location for it based on its
.prj projection info. (assuming it has a .prj file. if not you'll have
to create the needed location manually and import using v.in.ogr from
within the new location)
> Extent: (100528.742188, 3991489.250000) - (610083.250000, 4288506.900918)
> Layer SRS WKT: (unknown)
Looks like you'll have to create a new location and set the projection
settings manually...
then (in the lat/lon location) suck it into the lat/lon projection with
v.proj.
Hamish
