[GRASS-user] SRTM data, postgis and topographic
Bruce Bushby
bruce.bushby at rmsaudio.com
Thu Jan 4 13:59:04 EST 2007
Hi Jarek
Thanks for getting back to me!
"..what you mean SRTM30?.." -- I used wget to download all SRTM data
available from nasa at ftp://e0srp01u.ecs.nasa.gov/srtm/version2 , the
data available is broken down into SRTM1, SRTM3, SRTM30 and SWBD
(Oceans). Point your browser to the link and it should list the various
sets.
"..simply: use NVIZ.." -- hmm..I see that, thanks, will have a play with
it.
I understand Grass can't write back to PostGIS. I was hoping that I
could "parse/export" the SRTM data and import into the database.
These guys seem to be playing with SRTM data beyond it's "rasta" format.
http://www.okino.com/conv/imp_dem.htm
Also, here is a larger map of South America
http://www.ngdc.noaa.gov/mgg/topo/img/sa.gif
I guess I don't understand SRTM data or it's format and probably need to
go google more :) I keep thinking that SRTM data has numerical values,
coordinates/height and is not just rasta.
Thanks again!
On Thu, 2007-01-04 at 18:57 +0100, Jarek Jasiewicz wrote:
> Dnia czwartek, 4 stycznia 2007 18:15, Bruce Bushby napisał:
> > Hello Grass users,
> > I'm hoping to find somebody who understands SRTM data and wouldn't
mind
> > sharing a few pointers.
> > I've downloaded various data sets, GTOPO30, SRTM30, SRTM3 and SRTM1
and
> > have tried to understand the various DEM formats (geotiff, DEM,
binary
> > rasta etc)
> > Is it possible to import the data into a PostGIS database as data
rather
> > then a BLOB? I was hoping there was coordinate/height data which I
could
> > use.
> POSTGIS use geometric (vector) data formats like points or poligons
not raster
> data.
> For my best knowlede:
> - grass didn't support Postgis (yet) in write mode, i.e. grass cannot
write
> data to Postgis, QGIS can
> - BLOB is type of mySQL rateher than PostgreSQL/Postgis and is used to
large
> binary text obiects, rather to rasters
> -MS Acess, SQL Server and db2 (porbably oracle too) (with ArcGIS's
> geodatabase) can store rasters in database tables
> - Raster can be stored in postgreSQL databases, pixel by pixel (but
not
> directly from grass). This operation have very limited sense
> > My goal is to have grass generate a topo map given a specified
> > location/scale and perhaps have a crack at generating movie fly
overs.
> simply: use NVIZ
> > My Grass is compiled with FFmpeg.
> > Any pointers much appreciated.
> > Cheers
> > Bruce
> In fact grass (with bash script, awk and the like) is very powerful
programing
> tool, you can do what you need without databases
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
