[GRASS-user] gis.m: file ppm not found - Fixed (I hope)
Michael Barton
michael.barton at asu.edu
Fri Jan 12 20:05:17 EST 2007
I think I tracked this down. It seems to be the a problem in latlon regions
resulting from a recent fix I did to deal with changes in the behavior of
g.region. I think I fixed it. I just commited this to the cvs.
Michael
On 1/12/07 5:23 PM, "Tomas Lanczos" <lanczos at t-zones.sk> wrote:
>> From: Michael Barton [mailto:michael.barton at asu.edu]
>> The same would happen for rasters if the map name for the
>> layer doesn't match a valid raster map. Any idea about the
>> validity of your maps or the name or your mapset?
> I did not change any map name in this mapset. For expample, just this
> morning started Grass 6.3, opened the raster and got an errormessage, I did
> not have this problem yesterday, the Grass worked with the same map without
> problem. The same is with the vectors, last Sunday I did a lot of
> intersection between different vectors - once the errormessage came after
> the 15th redraw command, next time after the second one and then worked fine
> until lunch, after lunch three times, then worked fine for two hours, etc.
> Regards
> Tomas
>> Michael
>> On 1/12/07 3:47 PM, "Tomas Lanczos" <lanczos at t-zones.sk> wrote:
>>> I am getting this errormessage, but accidentally, even I
>> don't touch
>>> any vector, even I am working only with rasters. I could
>> not find any
>>> causality.
>> __________________________________________
>> Michael Barton, Professor of Anthropology School of Human
>> Evolution & Social Change Center for Social Dynamics &
>> Complexity Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
phone: 480-965-6213
fax: 480-965-7671
