[GRASS-user] deleting vectors not having any attribute
Raffaele Morelli
raffaele.morelli at gmail.com
Tue Jan 23 06:06:50 EST 2007
> how can I eliminate the vectors that does not have any attribute ?
> when I try to delete that records in postgresql, I think grass keeps
> vectors internally ?
No attribute table in a vector means no need for a db connection, (is it our
case?) but if you got 'null' atts for some cats I think you should not
delete those records at all.
Null values in a db table won't do you no harm and you will spent only few
bytes for the primary key storage ;)
of course you won't see the warnings
regards
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070123/e7dae544/attachment.html
