[GRASS-user] elevation values of  watershed basins
    Thomas Adams
    Thomas.Adams at noaa.gov
    Wed Jan 31 08:05:21 EST 2007
Temiz,
One way you could do it is this:
(1) create a raster mask for each basin
(2) for each basin, with the mask set, use r.describe to get the range
in values (which gives the max)
(3) use r.mapcalc to set all but max. values to NULL
(4) use r.to.vect to convert the raster (max. elevation points) to
vector points
(5) export the vector point(s) to an ascii file (if this is your goal)
So, this could be put into a shell script and automated for lots of
basins. I'm sure there are other ways of doing this, but this is what
came to mind.
Regards,
Tom
temiz wrote:
> hello
> Can you make a suggestion about how I can find the highest and lowest
> elevation points of all watershed basins
> as vector points ?
> I mean, I have watershed map as vector. I need it's table includes
> like "cat", "highest elevation value", "lowest elevation value"
> How can I do that ?
> regards
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
