[GRASS-user] elevation values of watershed basins
Markus Neteler
neteler at itc.it
Wed Jan 31 08:14:06 EST 2007
temiz wrote on 01/31/2007 06:53 PM:
> hello
> Can you make a suggestion about how I can find the highest and lowest
> elevation points of all watershed basins
> as vector points ?
> I mean, I have watershed map as vector. I need it's table includes
> like "cat", "highest elevation value", "lowest elevation value"
> How can I do that ?
If I understand your question correctly, you can do this easily with
v.rast.stats
Description:
Calculates univariate statistics from a GRASS raster map based on
vector objects
The help page contains a similar example.
cheers
Markus
