[GRASS-user] problem with r.in.wms
Agustin Diez Castillo
Agustin.Diez at uv.es
Tue Jul 3 08:39:05 EDT 2007
wms
My machine:
Model Name: iMac
Model Identifier: iMac5,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: IM51.0090.B03
SMC Version: 1.8f2
My history with wms:
If I try r.in.wms mapserver=http://wms.jpl.nasa.gov/wms.cgi -l it
works fine, but if I try other servers see below (those servers work
fine in qgis, gvsig, web applets and everywhere but grass):
r.in.wms mapserver=http://wms.mapa.es/wms/wms.aspx? -l
List of layers for server http://wms.mapa.es/wms/wms.aspx?:
14:13:47 URL:http://wms.mapa.es/wms/wms.aspx? [492/492] -> "/Users/
Shared/grassdata/Projecte/adiez2/.tmp/regadiuet.prearq.uv.es/
2523.0capabilities.xml" [1]
WARNING: xml2 NOT avaliable
ERROR: Parsing XML file
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head id="Head1"><title>
Untitled Page
</title></head>
<body>
<form name="form1" method="post" action="wms.aspx" id="form1">
<input type="hidden" name="__VIEWSTATE" id="__VIEWSTATE" value="/
wEPDwUJNzgzNDMwNTMzZGSaWtQn3ZmzEIertgUcmkm6hJV5hw==" />
<div>
</div>
</form>
</body>
</html>
r.in.wms mapserver=http://ovc.catastro.meh.es/Cartografia/WMS/
ServidorWMS.aspx? -l
http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?:
14:20:28 URL:http://ovc.catastro.meh.es/Cartografia/WMS/
ServidorWMS.aspx? [316/316] -> "/Users/Shared/grassdata/Projecte/
adiez2/.tmp/regadiuet.prearq.uv.es/2641.0capabilities.xml" [1]
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidFormat">
<![CDATA[
Este servicio sirve para ser utilizado por programas de visualizaci?n
de cartograf?a. No es una p?gina web.]]>
[my translation: This service is used by cartographic display
programs. This is not a web page]
</ServiceException>
</ServiceExceptionReport>
Even when things are little better and I can at least get the layers
I find trouble:
r.in.wms output=sigua 'mapserver=http://www.sigua.ua.es/cgi-bin/
mapserv4.2.1.exe?map=d:/carto/sigua/map/ogc.map&' layers=fotografia
srs=EPSG:23030 --o
Calculating tiles
Requesting 4 tiles.
Downloading tiles
Tile already downloaded
All tiles downloaded successfully
ERROR 4: `/Users/Shared/grassdata/wms_download/sigua__0.geotiff' not
recognised as a supported file format.
I repeat all those servers work just fine in any other application.
Can somebody try any of those in linux and report?
On Jul 3, 2007, at 12:18 PM, Hamish wrote:
> Maximilian Krambach wrote:
>> I cannot get r.in.wms into getting me a wms layer imported. The
>> projection settings match, the layer is avaible for the region. Am I
>> doing something wrong?
>> btw: installation is 6.2.1 from Jachym's ubuntu repository
>> (les-ejk.cz)
> Please try with GRASS 6.2.2rc1 if you can. I believe this is fixed
> there, as well as many other fixes for the script.
> see the DRAFT release announcement in CVS:
> http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/web/announces/
> announce_grass622.html?rev=HEAD
> "This release is particularly important for Ubuntu users due to a
> number
> of Bourne shell script fixes."
> Agustin Diez Castillo wrote:
>> This issue have been discussed on the dev-list without solution as
>> far
>> as I can say.
> No, AFAIK it should be solved & working now in CVS.
> (maybe we worked through that off-list or in the bug tracker)
>> same here, downloaded TIFF contains junk: (903K binary file)
>> $ tiffinfo wms_download/terraserver-drg__0.tiff
>> TIFFReadDirectory: wms_download/terraserver-drg__0.tiff: Can not read
>> TIFF directory count.
> this should be fixed too.
> Ivan Shmakov wrote:
>> IIRC, Ubuntu uses Dash for /bin/sh by default.
> Yes, that was the main part of the problem, r.in.wms and friends had
> many bashisms. 6.2.2 should be bashism-free (hopefully we found them
> all!).
> WolfgangZ wrote:
>> Sorry if I go off topic, but wouldn't be r.in.wms a good example
>> to re
>> write it (almost) fully in python?
> Yes, absolutely.
> please do report any problems found in the latest CVS versions,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070703/3f737ba0/attachment.html
