[GRASS-user] v.lrs.where users wanted
Leonardo Lami lami at faunalia.it
Tue Jul 3 12:27:57 EDT 2007
Only for information, I have a problem with the new GRASS csv with the
command v.lrs.label with dbf database
GRASS 6.3.cvs (spearfish60):~ > v.lrs.label route_lrs rstable=route_lrs
output=route_lrs_labels labels=labels col=red size=50 xoffset=100
D0/0:   line = 1 / 1
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected $undefined, expecting $end
processing ';'
in statement:
select start_map, end_map, start_mp, start_off, end_mp, end_off, lid
from route_lrs where lcat = 1;
Error in db_open_select_cursor()
ERRORE: Cannot select records from LRS table: select start_map, end_map,
        start_mp, start_off, end_mp, end_off, lid from route_lrs where lcat
        = 1;
No this problem with sqlite also if I can not again see the label also
if I use v.clean/break and remove the "dangles" on the vectors.
But I thin k the problem is in this output:
unable to open font map '/usr/local/grass-6.3.cvs/fonts/.hmp': No such
file or directory
Best regards
Leonardo
Markus Neteler ha scritto:
> Martin Landa wrote on 06/28/2007 04:27 PM:
>> 2007/6/28, Markus Neteler <neteler at itc.it>:
>>> Hint: my v.lrs.create example needs an update once an improvement
>>> in v.edit is done to avoid wrong line selection.
>> Should be fixed in CVS (v.edit).
> Confirmed, thanks.
> Now I have updated the v.lrs.create example again.
> And also the v.lrs.label example works which is based on the previous.
> Additionally, a new working v.lrs.where example. :-)
> Remaining problem: how to insert a new milepost into a LRS?
> Markus
> ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
> ITC -> since 1 March 2007 Fondazione Bruno Kessler
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
