[GRASS-user] v.lrs.where users wanted
Markus Neteler neteler at itc.it
Wed Jul 4 06:38:54 EDT 2007
Leonardo Lami wrote on 07/03/2007 06:27 PM:
> Hi,
> Only for information, I have a problem with the new GRASS csv with the
> command v.lrs.label with dbf database
> GRASS 6.3.cvs (spearfish60):~ > v.lrs.label route_lrs rstable=route_lrs
> output=route_lrs_labels labels=labels col=red size=50 xoffset=100
> D0/0:   line = 1 / 1
> DBMI-DBF driver error:
> SQL parser error: syntax error, unexpected $undefined, expecting $end
> processing ';'
> in statement:
> select start_map, end_map, start_mp, start_off, end_mp, end_off, lid
> from route_lrs where lcat = 1;
> Error in db_open_select_cursor()
> ERRORE: Cannot select records from LRS table: select start_map, end_map,
>         start_mp, start_off, end_mp, end_off, lid from route_lrs where lcat
>         = 1;
Already fixed in CVS, it was a DBF driver limitation not accepting the
';' (now it does).
> No this problem with sqlite also if I can not again see the label also
> if I use v.clean/break and remove the "dangles" on the vectors.
> But I thin k the problem is in this output:
> unable to open font map '/usr/local/grass-6.3.cvs/fonts/.hmp': No such
> file or directory
Huh? Never see that problem... Apparently something went wrong when you
compiled lib/fonts/.
Markus
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
