[GRASS-user] capacity
Sun Jul 8 02:53:21 EDT 2007
goldneaa wrote:
> I am using GRASS(6.3)
> on a Mac OSX
> fails at length 100(for when using g.mlist for my rasters)
> Fails at length 240(when using r.region to change location of raster)
Ivan Shmakov wrote:
>         I might have completely missed the point, but may the
>         following help?
> GRASS> g.mlist type=rast pattern="prefix*" \
>            | (while read r; do r.region map="$r" ...; done)
>         (I'm assumed that you've ran into a limit of command line
>         length; since the above loop doesn't try to put all the map
>         names into a single command, but rather issues a separate
>         command for each of the maps, it should overcome the limit.)
Yes, it probably will work using Ivan's method. You didn't miss
anything, noone had suggested it before.
If it still fails, we'd need to see the code snippet causing the error.
Hamish
