[GRASS-user] Lock problem
Markus Neteler
neteler at itc.it
Mon Jul 9 03:58:23 EDT 2007
Hardeep Singh Rai wrote:
> On Ubuntu Feisty, default GRASS6.0.2, was working fine.
> Following http://les-ejk.cz/ubuntu/ I upgraded to GRASS6.2
> I worked fine once, but later on invoking it gave following problem:
> LOCATION_NAME not set.
> /usr/lib/grass/etc/init.sh:573:/usr/lib/grass/etc/lock: permission
> denied
> Unable to properly access ///.gislock
> In my own wisdom(?) I deleted lock file and created with 777
> permission. This did not solve problem.
> I uninstalled GRASS6.2, and installed GRASS6.0.2 from default Ubuntu
> repositories, but found it still gives lock problem.
> How to get rid of this LOCKED problem.
> H.S.Rai
Is it possible that you tried to install 64bit binaries on a 32bit machine?
Please post the results of:
uname -a
file /usr/lib/grass/etc/lock
Markus
View this message in context: http://www.nabble.com/Lock-problem-tf4046859.html#a11497435
Sent from the Grass - Users mailing list archive at Nabble.com.
