[GRASS-user] v.db.addtable - small issue
Markus Neteler neteler at itc.it
Mon Jul 9 05:11:19 EDT 2007
On Mon, Jul 09, 2007 at 10:17:37AM +0200, Jaros?aw Jasiewicz wrote:
> On script lines 162 - 168 there is small issue which make some problems
> with postgreSQL and others differ from dbf databases.
> In that place the script try to create table and if error occured It assume
> that database is not created and create new default databse and set grass
> to use dbf as default driver
> I found it, when I used v.db.addtable to add table to vector and made type
> mismatch in column type (flot4 instead of float4) script returns an error,
> but from that moment I had dbf instead of pgSQL as default database -
> without any warnings.
> I think script shall on line 164 check if dirver is different from dbf and
> 'exit 1' if driver different from dbf or continue  script if driver if dbf
Thanks for catching this one.
I have fixed the weird logic now. Also backported to GRASS 6.2.CVS.
Markus
