[GRASS-user] v.db.addtable - small issue
Jarosław Jasiewicz jarekj at amu.edu.pl
Mon Jul 9 04:17:37 EDT 2007
On script lines 162 - 168 there is small issue which make some problems
with postgreSQL and others differ from dbf databases.
In that place the script try to create table and if error occured It
assume that database is not created and create new default databse and
set grass to use dbf as default driver
I found it, when I used v.db.addtable to add table to vector and made
type mismatch in column type (flot4 instead of float4) script returns an
error, but from that moment I had dbf instead of pgSQL as default
database - without any warnings.
I think script shall on line 164 check if dirver is different from dbf
and 'exit 1' if driver different from dbf or continue  script if driver
if dbf
sometihing like:
echo "CREATE TABLE $table ($COLUMN_DEF)" | db.execute database=$database
driver=$driver
    if [ $? -ne 0 ] ; then
        if [ "$driver" != "dbf" ] ; then
            g.mesage -e "Cannot create table" .......
            exit 1
        fi
greetings
Jarek
