[GRASS-user] SQLite REGEXP
Neil Best nbest at lanworth.com
Mon Jul 9 11:29:05 EDT 2007
Glynn Clements wrote:
> Neil Best wrote:
>>Anyone out there have any insight on how to define a regexp() function
>>for SQLite at run-time as described at
>>http://www.sqlite.org/lang_expr.html#regexp
> http://www.sqlite.org/capi3ref.html#sqlite3_create_function
> This would need to be done in the driver (db/drivers/sqlite), probably
> whenever a database is opened (db__driver_open_database, in db.c).
> As for implementation: regcomp/regexec should be available on all Unix
> systems, but you might need a separate library for Windows.
Glynn, thanks for the reply.  Programming at this level is not my strong
suit so it's difficult for me to gauge how much effort would be involved
in filling this gap.  I have to wonder why this stub in SQLite has not
been filled in but it seems like there are enough work-arounds, like
getting the results from SQLite and using your favorite scripting
language to do the regex filtering, such that the demand is simply not
there.  I found a piece of code on the SQLite user list that claims to
meet this need[1] -- maybe someone would be interested in vetting this.
  I will write to the author and see what I can learn, especially
regarding his claim that linking to regex(7) doesn't really solve the
problem.  The fact that his post generated zero follow-ups is an
expression of lack of interest in the SQLite community, I would say.
Thanks.
Neil
[1] http://article.gmane.org/gmane.comp.db.sqlite.general/23584
