[GRASS-user] SQLite REGEXP
Glynn Clements
glynn at gclements.plus.com
Tue Jul 10 09:12:22 EDT 2007
Neil Best wrote:
> >>Anyone out there have any insight on how to define a regexp() function
> >>for SQLite at run-time as described at
> >>http://www.sqlite.org/lang_expr.html#regexp
> > http://www.sqlite.org/capi3ref.html#sqlite3_create_function
> > This would need to be done in the driver (db/drivers/sqlite), probably
> > whenever a database is opened (db__driver_open_database, in db.c).
> > As for implementation: regcomp/regexec should be available on all Unix
> > systems, but you might need a separate library for Windows.
> Glynn, thanks for the reply. Programming at this level is not my strong
> suit so it's difficult for me to gauge how much effort would be involved
> in filling this gap. I have to wonder why this stub in SQLite has not
> been filled in
Portability, perhaps. Windows systems won't have regexec(), while some
Unix systems may have it in a separate library, requiring additional
linker switches. There's also the choice of basic/extended/perl
syntax.
> but it seems like there are enough work-arounds, like
> getting the results from SQLite and using your favorite scripting
> language to do the regex filtering, such that the demand is simply not
> there. I found a piece of code on the SQLite user list that claims to
> meet this need[1] -- maybe someone would be interested in vetting this.
It seems sound, although a version using POSIX REs would be preferable
to PCREs, both for portability and for compatibility with other
drivers.
> I will write to the author and see what I can learn, especially
> regarding his claim that linking to regex(7) doesn't really solve the
> problem.
I think that he's saying that using PCREs is bad for compatibility, as
most other SQL implementations use POSIX REs.
