[GRASS-user] GRASS 6.3 Installation Woes on OS X
Mars Sjoden amagine at telus.net
Tue Jul 10 14:13:38 EDT 2007
Just to confirm, you do have X11 installed right?
Here is a link for downloading sample data/mapsets; http://
grass.itc.it/download/data6.php
Mars
On 10-Jul-07, at 6:57 AM, William Kyngesburye wrote:
> You may have installed Lorenzo's or OpenOSX's GRASS before.  I
> think one of those installed the Spearfish samples and the user/
> grass folder.  Basically, those extras are just for convenience
> from the packager.
> See the GRASS documentation for help setting up GRASS after
> installation.  This build of GRASS now has docs integrated with the
> OSX help system - open Mac Help from the Finder, then select GRASS
> from the Library menu.  A readme is installed in /Users/Shared.
> .grass6rc is not something that must exist for GRASS to run.
> Create it if you need it.  I prefer to use .bash_profile instead,
> since .grass6rc is loaded *after* the initial mapset selection.
> As for the 'grass63' executable, this is embedded in the
> application bundle, and there is no need to directly run it, this
> is taken care of when you double-click GRASS-6.3.app.  It is
> possible to run it from a Terminal if you like - it is renamed
> 'grass.sh' inside the app bundle, in GRASS-6.3.app/Contents/Resources.
> On Jul 10, 2007, at 2:15 AM, Ryan Rosario wrote:
>> Hi,
>> I am using the binary GRASS.app 6.3 CVS 070530 from the
>> KyngChaos.com website. I am having some difficult getting GRASS
>> 6.3 to install correctly.
>> I believe in my previous version of GRASS on another system, the
>> installer created the directory "/Users/ryan/grass" for me and put
>> the Spearfish dataset in there. This directory does not exist
>> after installing this new version for some reason. When I start
>> GRASS, I get an error:
>> WARNING: location <<UNKNOWN>> at GISDBASE </Users/ryan> is not a
>> directory or does not exist.
>> because /Users/ryan/grass does not exist. There is also no
>> Spearfish dataset anywhere. If I manually create the grass folder,
>> I still get the error b/c Grass doesn't detect it.
>> For some reason, the  .grass6rc file and the executable grass63
>> will not install.
>> Am I missing something? I installed all of the frameworks before
>> installing 6.3 but I cannot get it to install completely.
>> Thanks,
>> Ryan
>> Ryan Rosario
>> Center for Environmental Statistics
>> Department of Statistics
>> University of California, Los Angeles
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
