[GRASS-user] GRASS 6.3 Installation Woes on OS X
Ryan Rosario
uclamathguy at gmail.com
Wed Jul 11 13:25:09 EDT 2007
Thanks. All I have seen is .grassrc6 but that must have been from Lorenzo's
build. To get a similar environment I just created a grass directory under
/Users/ryan and then entered /Users/ryan/grass into the GIS Data Directory
field. I no longer get the error I asked about.
Another user recommended creating my own .grassrc6 file which has apparently
worked for other users, but it seems that my way works as well (both methods
are probably doing the same thing). I downloaded the Spearfish dataset and
all appears good as new.
Thanks!
Ryan
On 7/11/07, William Kyngesburye <woklist at kyngchaos.com> wrote:
> On Jul 11, 2007, at 3:36 AM, Hamish wrote:
> > William Kyngesburye wrote:
> >> .grass6rc is not something that must exist for GRASS to run. Create
> >> it if you need it. I prefer to use .bash_profile instead,
> >> since .grass6rc is loaded *after* the initial mapset selection.
> > little clarification:
> > .grassrc6 holds the GIS variables. It is not a series of shell
> > commands.
> > It contains things like "DEBUG: 0".
> > .grass.bashrc (or .grass.cshrc) contains shell commands to be run at
> > initial mapset selection (creation of session shell). It contains
> > things
> > like "export GRASS_WIDTH=800".
> > Maybe .grass6rc exists on your builds for the Mac, I'm not sure,
> > but did
> > you mean to say .grass.bashrc not .grass6rc?
> Right, .grass.bashrc is what I meant. Don't know if that's what Ryan
> meant. It's not in the Mac build.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in
> a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
<a href="http://www.spreadfirefox.com/?q=affiliates&id=0&t=180"><img
border="0" alt="Get Thunderbird!" title="Get Thunderbird!" src="
http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.png"/></a>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070711/17695978/attachment.html
