[GRASS-user] how to test if a point is inside a polygon
Wolf Bergenheim
wolf+grass at bergenheim.net
Thu Jul 12 13:32:27 EDT 2007
v.select will allow you to select points which overlap areas or vice versa.
v.select ainput=points binput=areas output=points_in_areas
points_in_areas will contain points which are inside the areas.
--Wolf
On 12.07.2007 17:10, WolfgangZ wrote:
> Hi,
> I haven't worked much with the vector features of grass. Is there a way
> to query if a given point is inside if a polygon (closed area)?
> Many thanks
> Wolfgang
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
<:3 )---- Wolf Bergenheim ----( 8:>
