[GRASS-user] how to test if a point is inside a polygon
WolfgangZ
wollez at gmx.net
Thu Jul 12 13:37:30 EDT 2007
Wolf Bergenheim schrieb:
> v.select will allow you to select points which overlap areas or vice versa.
> v.select ainput=points binput=areas output=points_in_areas
> points_in_areas will contain points which are inside the areas.
> --Wolf
> On 12.07.2007 17:10, WolfgangZ wrote:
>> Hi,
>> I haven't worked much with the vector features of grass. Is there a way
>> to query if a given point is inside if a polygon (closed area)?
>> Many thanks
>> Wolfgang
Hi Wolf,
thank for your help. There are sometimes too many commands in grass to
find the right one!
Wolfgang
