[GRASS-dev] Re: [GRASS-user] thanks to GRASS!
J Dougherty
jwd at surewest.net
Fri Jul 13 14:42:46 EDT 2007
On Wednesday 11 July 2007 13:12, Maris Nartiss wrote:
> I think there could be some legal issues.
> I.e. from COMPUTERS & GEOSCIENCES Guide for Authors [1] "e) if
> accepted, will not be published elsewhere in the same form, in English
> or in any
> other language, without the written consent of the Publisher."
> IANAL but putting article PDF on wiki may be threated as "publishing"?
> Maris.
The key phrase is the one that reads ". . . in the same form . . ." Just as
the author has a copyright to his or her own original work, so does the
publisher retain rights with respect to how the paper is published in their
journal. All the formatting and apearance of the piece, as well as the
editing and proof work were paid for by the publisher, any illustrations that
they developed for you, etc. Thus, they don't want you giving away their
work for free. So, first rule is don't post copies of the published version
as it appears in the journal without explicit (written) permission, which is
what they are saying anyway.
IF you sign a transfer of copyright, things are different. Effectively you
have turned over your rights to the text and your own work, with the
exception of whatever uses they tell you that you retain. (In the music
industry many composers and lyricists have completely lost the right to
perform their own works without permission.) You might have to rewrite the
whole thing in a different form before using it again. Of course, when you
look at the way in which some researchers wall paper various journals with
closely related papers that all effectively say the same thing, this must be
pretty common. Sometimes the biggest difference between two related articles
seems to be the order in which the authors are listed.
JWDougherty
