[GRASS-dev] Re: [GRASS-user] thanks to GRASS!: posting copies of
"copyrighted" works
Charles Ehlschlaeger
c.ehlschlaeger at insightbb.com
Fri Jul 13 16:20:13 EDT 2007
I DO have a "rough draft" of my COMPUTERS & GEOSCIENCES article posted on my
website. That rough draft was then edited and published in that journal.
Based on the instructions at that time, what I did was perfectly legal and
fine. It would be wrong of me to use their digital or analog versions, in
any way, to modify or improve my draft. Changes made to my rough draft would
then be infringing on "their" (copyrighted) work.
One safe way of looking at it, once C&G has accepted a paper for
publication, you should not make any changes to the draft you sent in.
Otherwise, you would be in danger of exploiting their work.
Some journals are more strict than C&G: so this isn't even a blanket rule.
Sincerely, chuck
Chuck Ehlschlaeger, Associate Professor & GIS Center Director
Department of Geography, Western Illinois University
215 Tillman Hall, 1 University Circle, Macomb, IL 61455
cre111 at wiu.edu, phone: 309-298-1841, fax: 309-298-3003
-----Original Message-----
From: grassuser-bounces at grass.itc.it [mailto:grassuser-bounces at grass.itc.it]
On Behalf Of J Dougherty
Sent: Friday, July 13, 2007 1:43 PM
To: grassuser at grass.itc.it
Subject: Re: [GRASS-dev] Re: [GRASS-user] thanks to GRASS!
On Wednesday 11 July 2007 13:12, Maris Nartiss wrote:
> I think there could be some legal issues.
> I.e. from COMPUTERS & GEOSCIENCES Guide for Authors [1] "e) if
> accepted, will not be published elsewhere in the same form, in English
> or in any
> other language, without the written consent of the Publisher."
> IANAL but putting article PDF on wiki may be threated as "publishing"?
> Maris.
The key phrase is the one that reads ". . . in the same form . . ." Just as
the author has a copyright to his or her own original work, so does the
publisher retain rights with respect to how the paper is published in their
journal. All the formatting and apearance of the piece, as well as the
editing and proof work were paid for by the publisher, any illustrations
that
they developed for you, etc. Thus, they don't want you giving away their
work for free. So, first rule is don't post copies of the published version
as it appears in the journal without explicit (written) permission, which is
what they are saying anyway.
IF you sign a transfer of copyright, things are different. Effectively you
have turned over your rights to the text and your own work, with the
exception of whatever uses they tell you that you retain. (In the music
industry many composers and lyricists have completely lost the right to
perform their own works without permission.) You might have to rewrite the
whole thing in a different form before using it again. Of course, when you
look at the way in which some researchers wall paper various journals with
closely related papers that all effectively say the same thing, this must be
pretty common. Sometimes the biggest difference between two related
articles
seems to be the order in which the authors are listed.
JWDougherty
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.10.4/898 - Release Date: 7/12/2007
4:08 PM
No virus found in this outgoing message.
4:08 PM
