[GRASS-user] summation
Wolf Bergenheim
wolf+grass at bergenheim.net
Mon Jul 16 15:29:39 EDT 2007
On 13.07.2007 09:22, Wolf Bergenheim wrote:
> That is exactly what this script does. Hmm or should do. But there is a
> bug. here is the correct version:
Nope, still not. This works:
-----------8<-------------------------8<--------------
#!/usr/bin/tcsh
set tmp=2
set sstr="tmp.1"
set erase="tmp.1"
while($tmp <= 11)
@ t = $tmp - 1
set str="tmp.$t=temp.1"
set i=2
while($i <= 156)
@ ti = $t * $i
set str="$str+temp.$ti"
@ i++
end
r.mapcalc $str
if($tmp <= 10) then
set sstr="$sstr+tmp.$tmp"
set erase="$erase,tmp.$tmp"
endif
echo "Total progress: ${t}0%"
@ tmp++
end
r.mapcalc sum=$sstr
echo "Cleaning temporary files..."
g.remove rast=$erase
echo ""
echo "All done. Result is called sum"
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
