[GRASS-user] v.cutter
goldneaa at onid.orst.edu goldneaa at onid.orst.edu
Tue Jul 17 11:21:57 EDT 2007
Is there a way in GRASS, 6.3 to take a raster map of say the SW United
States and use a vector cutter to cut out a smaller portion of the map
in order to run certain statistics on it.  For example, if I have a
temperature raster for the SW United States and I wanted to cut an
area which I have coordinates for like Los Alamos, is there a way to
cut out this area of the map and reproject in order to run mean,
st.dev, etc.
Thanks,
Aaron
