[GRASS-user] hdf import fails
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Jul 25 07:53:16 EDT 2007
On Monday 23 July 2007 18:13:28 Martin Wegmann wrote:
> > Hope this helps,
> yes, it solved this problem, but it is quit tedious to import each layer
> separately - but it is probably possible to write a script.
> One big problem occurs after the import when patching the imported hdfs
> which does not work properly (see attached image) - but using ERDAS 9.1
> patching works fine.
> Any idea how this error might be fixed?
it was a (re-)projection problem - the problem also occurs in ERDAS but wasn't
visible at the first sight.
Solved it by patching it using MRT and doing the processing afterwards.
Martin
