[GRASS-user] min and max coord values
Glynn Clements
glynn at gclements.plus.com
Wed Jul 18 09:43:48 EDT 2007
Ivan Shmakov wrote:
> >>>>> "t" == temiz <temiz at deprem.gov.tr> writes:
> t> I want to get min and max coord values from of catagorized raster
> t> map.
> t> something like: r.stats -agn hey6 > gives minx maxx miny maxy
> t> is it possible ?
> You may use r.info to obtain the coordinates of the opposite
> corners of the grid of the raster map. Alternatively, you could
> change the current region to the one of the raster map ($
> g.region rast=MAP), then print it ($ g.region -p.) (You're to
> save the current region to a temporary file to be able to return
> to it.)
> The above gives you the coordinates of the corners of the grid.
> I know no easy way to obtain the coordinates of the corners of
> the actual data (i. e., with the NULLs omitted.)
You can use "g.region zoom=..." for this.
The rast= option uses the bounds of the map itself, while zoom= uses
the smallest rectangle which encloses all of the non-null cells.
