[GRASS-user] min and max coord values
Thu Jul 19 12:08:50 EDT 2007
temiz wrote:
> >> I want to get min and max coord values from  of catagorized raster
> >> map.
> >> something like:  r.stats -agn hey6 > gives minx maxx miny maxy
> >> is it possible  ?
> > do you mean you want the coordinates of the bounding boxes surrounding
> > each category?
> > loop over each CAT (`r.describe`), create a MASK or new map based on
> > that cat, then 'g.region -p zoom='.
> thank you and other friends
> I wrote a script to calculate the coordinates of  bounding box of each
> category using "g.region -p zoom="
> I am wondering if  "r.stats -agn"  is second alternative ?
> My raster map is something like some islands.
> if I get coord value of each category , I can calculate most north-
> south and, most west- east, and then determine the coords of  minimum
> bounding  box?
This is more efficient, particularly for many categories, but it
requires a bit more work. The attached script takes the output from
"r.stats -gn" and computes the bounding boxes for each category, e.g.:
	r.stats -gn fields | ./bbox.awk | sort -n
#!/usr/bin/awk -f
	if ($3 in n)
		if (n[$3] < $2) n[$3] = $2
		if (s[$3] > $2) s[$3] = $2
		if (e[$3] < $1) e[$3] = $1
		if (w[$3] > $1) w[$3] = $1
	else
		n[$3] = s[$3] = $2
		e[$3] = w[$3] = $1
END {
	for (i in e)
		print i,n[i],s[i],e[i],w[i]
