[GRASS-user] min and max coord values
temiz
temiz at deprem.gov.tr
Fri Jul 20 09:50:55 EDT 2007
Glynn Clements wrote:
> temiz wrote:
>>>> I want to get min and max coord values from of catagorized raster
>>>> map.
>>>> something like: r.stats -agn hey6 > gives minx maxx miny maxy
>>>> is it possible ?
>>> do you mean you want the coordinates of the bounding boxes surrounding
>>> each category?
>>> loop over each CAT (`r.describe`), create a MASK or new map based on
>>> that cat, then 'g.region -p zoom='.
>> thank you and other friends
>> I wrote a script to calculate the coordinates of bounding box of each
>> category using "g.region -p zoom="
>> I am wondering if "r.stats -agn" is second alternative ?
>> My raster map is something like some islands.
>> if I get coord value of each category , I can calculate most north-
>> south and, most west- east, and then determine the coords of minimum
>> bounding box?
> This is more efficient, particularly for many categories, but it
> requires a bit more work. The attached script takes the output from
> "r.stats -gn" and computes the bounding boxes for each category, e.g.:
> r.stats -gn fields | ./bbox.awk | sort -n
> #!/usr/bin/awk -f
> if ($3 in n)
> if (n[$3] < $2) n[$3] = $2
> if (s[$3] > $2) s[$3] = $2
> if (e[$3] < $1) e[$3] = $1
> if (w[$3] > $1) w[$3] = $1
> else
> n[$3] = s[$3] = $2
> e[$3] = w[$3] = $1
> END {
> for (i in e)
> print i,n[i],s[i],e[i],w[i]
Thank you again
I preferred r.stats, because its output more is manageable than
g.region's in terms of querying.
The awk script solved the issue practically.
I was thinking to port the data to postgresql to find min, max coord
values for each category.
By the way just an idea:
can "g.region zoom=" work with respect to cat value of a map in grass's
future releases ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
