[GRASS-user] Most efficient way to import a lat-lon shapefile into, say, a Lambert Conic Conformal location?
Daniel Victoria daniel.victoria at gmail.com
Fri Jul 20 14:44:07 EDT 2007
Isn't there a way to import the vector into another ALREADY EXISTING
location, so we would only need to create one lat-long location and
import all files there. Then there would be no need to keep deleting
locations. Or the location option in v.in.ogr will always try to
create a new location?
Daniel
On 7/20/07, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
> Carlos,
> Thank you for your help. It sounds like I might as well write a simple
> script because anytime I would want to do this, I would need to create a
> new location. Either I would end up with a bunch of lat-lon locations,
> or I would need to delete the one I just created afterwards. So, I might
> as well write a simple script to handle this process and do the clean-up.
> Regards,
> Tom
> Carlos "Guâno" Grohmann wrote:
> > You can create a new location in the import step, so you don't have to
> > exit from your lambert location.
> > c
> >> List,
> >> What is the most efficient way to import a lat-lon shapefile into, say,
> >> a Lambert Conic Conformal location? Up to this point if I wanted to do
> >> this, I would exit GRASS (6.2.1) from my Lambert Conic Conformal
> >> location. Then, start-up GRASS in a lat-lon location, import the
> >> shapefile, then, exit GRASS, and re-start GRASS into my LCC location,
> >> where I would reproject the map from the lat-lon location into my LCC
> >> location. OBVIOUSLY, this works (and I could write a simple script to
> >> automate this), but it seems there ought to be a way to do this all
> >> within my original LCC location. So, is there some way to do this — it's
> >> not very obvious to me.
> >> Regards,
> >> Tom
> >> Thomas E Adams
> >> National Weather Service
> >> Ohio River Forecast Center
> >> 1901 South State Route 134
> >> Wilmington, OH 45177
> >> EMAIL:  thomas.adams at noaa.gov
> >> VOICE:  937-383-0528
> >> FAX:    937-383-0033
> >> _______________________________________________
> >> grassuser mailing list
> >> grassuser at grass.itc.it
> >> http://grass.itc.it/mailman/listinfo/grassuser
> Thomas E Adams
> VOICE:  937-383-0528
> FAX:    937-383-0033
