[GRASS-user] Most efficient way to import a lat-lon shapefile into, say, a Lambert Conic Conformal location?
Thomas Adams Thomas.Adams at noaa.gov
Fri Jul 20 14:34:14 EDT 2007
Carlos,
Thank you for your help. It sounds like I might as well write a simple
script because anytime I would want to do this, I would need to create a
new location. Either I would end up with a bunch of lat-lon locations,
or I would need to delete the one I just created afterwards. So, I might
as well write a simple script to handle this process and do the clean-up.
Regards,
Tom
Carlos "Guâno" Grohmann wrote:
> You can create a new location in the import step, so you don't have to
> exit from your lambert location.
> c
> On 7/20/07, Thomas Adams <Thomas.Adams at noaa.gov> wrote:
>> List,
>> What is the most efficient way to import a lat-lon shapefile into, say,
>> a Lambert Conic Conformal location? Up to this point if I wanted to do
>> this, I would exit GRASS (6.2.1) from my Lambert Conic Conformal
>> location. Then, start-up GRASS in a lat-lon location, import the
>> shapefile, then, exit GRASS, and re-start GRASS into my LCC location,
>> where I would reproject the map from the lat-lon location into my LCC
>> location. OBVIOUSLY, this works (and I could write a simple script to
>> automate this), but it seems there ought to be a way to do this all
>> within my original LCC location. So, is there some way to do this — it's
>> not very obvious to me.
>> Regards,
>> Tom
>> Thomas E Adams
>> National Weather Service
>> Ohio River Forecast Center
>> 1901 South State Route 134
>> Wilmington, OH 45177
>> EMAIL:  thomas.adams at noaa.gov
>> VOICE:  937-383-0528
>> FAX:    937-383-0033
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
Thomas E Adams
VOICE:	937-383-0528
FAX:	937-383-0033
