[GRASS-user] r.to.rast3
Hamish
hamish_nospam at yahoo.com
Mon Jul 23 01:32:51 EDT 2007
bks at centrum.cz wrote:
> Hi,
> I have a problem in runing r.to.rast3.
> I cannot go over the following error message: "Input maps have to be
> from the same type. CELL, FCELL, DCELL!"
> The input 2D slice maps were made by r.mapcalc.
> To fix the problem I have tried to: r.mapcalc "map1=float(map1)" and
> the with map2.
> r.info .... from both of them show: data type: FCELL
> It doesn't help.
> Wenn I work with integer (CELL), I receive this error message: "Could
> not open map ... (allway the second one from the two input ones)"
can you recreate this using the Spearfish test dataset? If so, please
post the exact command line you used. If not, ??
Hamish
