[GRASS-user] r.to.rast3
Soeren Gebbert soerengebbert at gmx.de
Mon Jul 23 14:32:29 EDT 2007
i'm not able to reproduce this error with the latest cvs version of grass6.
It seems to work with integer, float and double raster maps.
Can you please provide more information?
1.) What version of grass are you using
2.) The command line you have used
3.) The projection and size of your mapset
Best regards
Soeren
Am Freitag, 20. Juli 2007 18:26 schrieb bks at centrum.cz:
> Hi,
> I have a problem in  runing r.to.rast3.
> I cannot go over the following error message: "Input maps have to be from
> the same type. CELL, FCELL, DCELL!"
> The input 2D slice maps were made by r.mapcalc.
> To fix the problem I have tried to:  r.mapcalc "map1=float(map1)" and the
> with map2.
> r.info .... from both of them show:  data type: FCELL
> It doesn't help.
> Wenn I work with integer (CELL), I receive this error message: "Could not
> open map ... (allway the second one
> >from the two input ones)"
> Thanks in advance for your help!
> Stanislav
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
