[GRASS-user] g.list pager
    Daniel Victoria
    daniel.victoria at gmail.com
    Mon Jul 23 13:12:30 EDT 2007
I was trying to set the GRASS_PAGER variable using g.gisenv set=
command and it was not working. I did it with the export command and
it now works. Funny thing is that the pager is set correctly at the
.grassrc6 file but grass ignores it. Will have to put it on bashrc
Thanks
Daniel
On 7/23/07, Glynn Clements <glynn at gclements.plus.com> wrote:
> Daniel Victoria wrote:
> > I tried to change GRASS_PAGER env to more, cat but nothing happened.
> > What am I doing wrong?
> Not setting GRASS_PAGER correctly, probably.
> Typing e.g.:
>         export GRASS_PAGER=cat
> in the shell should affect all subsequent commands run from that
> shell. If you have gis.m running, you'll need to restart it in order
> to affect commands which are run from it. If you want to make it
> permanent, put it in ~/.bashrc.
