[GRASS-user] Re: 6.3, OSX and X11
Richard Chirgwin
rchirgwin at ozemail.com.au
Mon Jul 23 20:14:23 EDT 2007
Massimo,
That line exists in the startup script packaged with the Mac Grass
application, yes.
Cheers,
Richard
Message: 4 Date: Fri, 20 Jul 2007 21:07:26 +0200 From: massimo di
stefano <massimodisasha at yahoo.it> Subject: [GRASS-user] Re: 6.3, OSX and
X11 To: grassuser at grass.itc.it Message-ID:
<D294D325-8467-42BC-AB74-E014EEBA3DA8 at yahoo.it> Content-Type:
text/plain; charset="us-ascii" hi, have you tried to add : export
DISPLAY=:0.0 in you're .bash_profile ? Il giorno 20/lug/07, alle ore
20:35, grassuser-request at grass.itc.it ha scritto:
> > Greetings,
> > I have just installed Grass 6.3 on OSX 10.4. There is a problem
> > getting
> > d.mon to successfully start monitors under this environment. When I
> > use:
> > d.mon start=x0
> > - it returns "no such monitor" errors.
> > X11 is installed and running on the machine, and d.mon -l returns a
> > list
> > of monitors.
> > Any suggestions?
> > Richard Chirgwin
