[GRASS-user] Re: 6.3, OSX and X11
William Kyngesburye
woklist at kyngchaos.com
Mon Jul 23 21:20:47 EDT 2007
Are you are using my build? Yes, DISPLAY is set there, IF it is not
set already.
With GRASS running, what does this say:
echo $DISPLAY
It should be :0.0
If you have something else setting DISPLAY - maybe
in .bash_profile, .bashrc, .bash_login or .profile (I think that's
all of them) - the GRASS startup script won't set it.
On Jul 23, 2007, at 7:14 PM, Richard Chirgwin wrote:
> Massimo,
> That line exists in the startup script packaged with the Mac Grass
> application, yes.
> Cheers,
> Richard
> Message: 4 Date: Fri, 20 Jul 2007 21:07:26 +0200 From: massimo di
> stefano <massimodisasha at yahoo.it> Subject: [GRASS-user] Re: 6.3,
> OSX and X11 To: grassuser at grass.itc.it Message-ID:
> <D294D325-8467-42BC-AB74-E014EEBA3DA8 at yahoo.it> Content-Type: text/
> plain; charset="us-ascii" hi, have you tried to add : export
> DISPLAY=:0.0 in you're .bash_profile ? Il giorno 20/lug/07, alle
> ore 20:35, grassuser-request at grass.itc.it ha scritto:
>> > Greetings,
>> > I have just installed Grass 6.3 on OSX 10.4. There is a problem
>> > getting
>> > d.mon to successfully start monitors under this environment.
>> When I > use:
>> > d.mon start=x0
>> > - it returns "no such monitor" errors.
>> > X11 is installed and running on the machine, and d.mon -l
>> returns a > list
>> > of monitors.
>> > Any suggestions?
>> > Richard Chirgwin
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
