[GRASS-user] Re: 6.3, OSX and X11
William Kyngesburye
woklist at kyngchaos.com
Mon Jul 23 22:57:29 EDT 2007
On Jul 23, 2007, at 9:15 PM, Richard Chirgwin wrote:
> 2) echo $DISPLAY - returns nothing. In the bash shell, you just get
> an empty line.
Are you sure this when GRASS is running - that is, in the Terminal
window that is started by GRASS? In a new/blank Terminal window this
may well be unset.
> William Kyngesburye wrote:
>> Are you are using my build? Yes, DISPLAY is set there, IF it is
>> not set already.
>> With GRASS running, what does this say:
>> echo $DISPLAY
>> It should be :0.0
>> If you have something else setting DISPLAY - maybe
>> in .bash_profile, .bashrc, .bash_login or .profile (I think that's
>> all of them) - the GRASS startup script won't set it.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people
of the allied nations devoted an entire year exclusively to hating
the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
