[GRASS-user] Grass version for grids
Markus Neteler neteler at itc.it
Wed Jul 25 08:18:39 EDT 2007
Anaïs,
please run
 file /home/labarre/GrassGIS/bin/g.gisenv
 uname -a
and post the result here. It looks like a 32/64bit compilation
issue (using 64bit binaries on 32bit CPU).
For the second problem: the WIND and DEFAULT_WIND
files were updated in GRASS 6 to store 3D info as well.
To use such a location with GRASS 5, there lines would
have to be removed (they are ASCII files, so easy to do).
But it's probably much better for you to get GRASS 6
running.
Markus
Anaïs Labarre wrote on 07/25/2007 10:34 AM:
> Hello,
> I am working on a project which includes to install Grass on a grid computing
> infrastructure composed by computers with scientific linux (32 bits).
> For the moment Grass will be used to combine layers (red, green, blue) of tiff
> files and to save the generated files.
> The last version of Grass (Grass 6.2.2 Generic Linux) make me an error, maybe
> due to the 32 bits :
> 	Starting GRASS ...
> 	/home/labarre/GrassGIS/etc/Init.sh: line 567:
> 	/home/labarre/GrassGIS/bin/g.gisen v: cannot execute binary file
> 	/home/labarre/GrassGIS/etc/Init.sh: line 568:
> 	/home/labarre/GrassGIS/etc/Init.sh: line 569:
> 	/home/labarre/GrassGIS/etc/Init.sh: line 575:
> 	/home/labarre/GrassGIS/etc/lock: c annot execute binary file
> 	Unable to properly access ///.gislock
> 	Please notify system personel.
> So, I try an old version of Grass (Grass 5.4.0 Generic Linux).
> This version works but when I use "g.region" I have an error :
> 	ERROR: default region is invalid
> 	line 11: <top: 1>
> So, I wonder which is the suitable version of Grass to be used (graphical
> interface isn't necessary, because the project needs only to send jobs to Grass
> with Shell scipts).
> If the 5.4.0 version is the appropriated one, how can I solve the "g.region"
> problem ?
> Thanks per advance.
> Anaïs Labarre
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
