[GRASS-user] r.los
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Mon Jul 30 17:31:05 EDT 2007
Since r.los only works on rasters, I need to create the raster files.
How do you create rasters starting with a set of vector contour maps?
I tried running v.extrude, using the "Elevation" column for the
attribute. Grass processes this okay, reporting:
Number of nodes: 197049
Number of primitives: 197056
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of faces: 197056
Number of areas: 0
Number of isles: 0
When I try to display the resulting map, however, I get a blank display.
Have I failed to configure something for the display of the 3D output?
Richard Chirgwin
